Rear Trackbar Clearance on 3" Teraflex
I received my new right rear shock and shock relo bracket from Teraflex. Thanks Joe for the excellent customer service.
As I stated on an other thread, I had clearance issues between my trackbar bracket and rear shock. The relo bracket fixes the clearance problem.
Here is my question. Can I use an aftermarket trackbar (TF, FT, etc) to eliminate the Teraflex trackbar bracket and still maintain all clearances? I also want to be able to remove the shock relo bracket. I am not sure if the trackbar will clear the RR spring without the TB bracket.
As I stated on an other thread, I had clearance issues between my trackbar bracket and rear shock. The relo bracket fixes the clearance problem.Here is my question. Can I use an aftermarket trackbar (TF, FT, etc) to eliminate the Teraflex trackbar bracket and still maintain all clearances? I also want to be able to remove the shock relo bracket. I am not sure if the trackbar will clear the RR spring without the TB bracket.
Im not sure about the Tera bar, but the FT bar works fine with no bracket and 3" of lift.
When I was running my RE 3.5 lift, I had the FT adjustable rear bar and no bracket.
Now that Ive got the 4.5" lift, Im using the FT bar with the RE drop bracket and its still fine.
