rear uppers ca's with stock shaft?
I want to install the TF rear upper rear control arms and adjust the pinion angle to put stock rezeppa ds at 2 degress.
then later on will install the Coast shafts. My question is can i run the rezeppa stock shaft this way untill i install coast shaft.
Don't forget that the rear uppers come in 2 different lengths. If you are going to use them in conjuction with just the front LCAs; get the extra short uppers. Eight arm setup; regular length upper
