rear uppers ca's with stock shaft?
Old Apr 23, 2013 | 05:54 AM
GunDude's Avatar
Default rear uppers ca's with stock shaft?
I want to install the TF rear upper rear control arms and adjust the pinion angle to put stock rezeppa ds at 2 degress.
then later on will install the Coast shafts. My question is can i run the rezeppa stock shaft this way untill i install coast shaft.
Old Apr 23, 2013 | 06:11 AM
otservice's Avatar
Yes. You can install them & correct your current pinion angle before getting a DC shaft.
Old Apr 23, 2013 | 03:02 PM
Gman*2007's Avatar
I've installed a full set of Metal Cloak control arms & I'm running stock shafts with no problem.
Old Apr 23, 2013 | 06:42 PM
Jumpmaster's Avatar
Don't forget that the rear uppers come in 2 different lengths. If you are going to use them in conjuction with just the front LCAs; get the extra short uppers. Eight arm setup; regular length upper
