Recalibration
I think I'm with Red Rock on this one. If the speed sensors are taking their readings at the wheel, the gears have nothing to do with it. If the speedometer is taking it's readings from the drive shaft, then it would. I believe the JK gets its readings at the wheels, based on other threads I've read.
When I pedal my mountain bike, the speedometer doesn't give a rats ass which of the three front derailers I am using, because my sensor is on the wheel. That just determines how hard I have to work to keep it at a certain speed.
In order for the gears to make a difference, the speed sensor would have to be reading the driveshaft.
Ok, so here are my two calcs... I was only slightly jacked up in my first post.
1) If the gears don't affect it and only the tires do, the speedo will register below the speed I'm actually doing and the difference is around 8% maybe a little over. So if I'm actually doing 60, the speedo should register about 55...
If #1 is correct, then one of the above postings is correct and I'm stuck w/it as is. Mileage wise though it benefits you because you'd actually have higher mileage than your odometer would state and therefore your warranty would last longer (sort of)...
I like Rubimon's analogy. A 20 speed mountain bike with a speedo could care less what gear you are using, it is deriving the speed from the rotaion of the tires. Same concept applies here. You can write my post off as anecdotal evidence if you wish, I'm just posting my experience with it.
FWIW, I was totally expecting my gear change to affect my speedo a lot. I have an extensive background in vehicle repair, customizing, etc. and I know that is the normal thing that happens when you swap gears. When I got my 5.13's installed and it did not change my speedo readings I was very surprised. That lead me to the conclusion that the speedo reading is based off the tire rotation (read by the wheel speed sensors) and not readings from the transmission, transfer case, etc.
Just my .02 , hope it is worth that to someone.
Thanks RedRock, I appreciate your time. Also, your part of the reason I went w/5.13's over 4.88's anyway... I read your earlier posts and results in regards to doing this to your JK...
Never writing off anyone's post... all information is valueable... In fact, as I mentioned earlier... being that you have the exact setup I'm having put on this week... I'm thinking your experience is probably the most valid in order to answer my original question.
That is an awesome offer !! THANKS !! Is there a software, hardware, or program device that can be purchased to do these functions?
...You think my wife would buy the fact that I needed to get my speedo adjusted for free and while I was there they accidently put a hemi in there for me!
