Recommendations on best transmission cooler
damn Seer I like that one and 20degrees probably would be enough if it does the job on the mountains and wheelin
have you noticed your coolant temp go up on mountain highway hills?
An update on the heat sink cooler: DO NOT USE IT IF YOU DO ANY WHEELING! It's okay for flat highway driving, will probably work for some hills, but it doesn't do a thing if you're going 5mph up a mountain trail. I'm switching it out for a powered model like Chuck45 is using.
