Redneck ram
I can almost guarantee you have the 1.75" ram. I know because you probably told WTO that you are running 40" tires in which case they will send you the 1.75" ram for more turning force which requires a higher flow rate pump.https://www.jk-forum.com/forums/jk-s...ck-ram-326432/
When you are on a very steep decline and your right tire is up against a dirt ledge and you have to turn left to avoid rolling, and can't because of the stock steering, is a good reason. Happened to me. Also, while parked or slightly moving and you can't turn your steering wheel, it's time for an assist. I've been extremely happy I did it and will not look back. I believe it also saves the sector shaft that will eventually wear out with big tires. No need for a sector shaft brace and bracket with hydro assist.
Poking for Experiance with redneck ram. I upgraded to 37's this year and off road aired down my steering doesn't like them. Has to work really hard. I can't swing PSC hydro assist but was planning to go with stage3 redneck . This is a daily driver that I wheel on the rocks. Handles good I have upgraded everything frame down.
Will this adversely effect my on road handling? Pro's cons? Who has Experiance with this?
Go!!!!
Go!!!!
I've run the WTOR hydro assist for a few years now and highly recommend it. Due to a shoulder injury that required surgery I farmed the install off to a local shop that has tons of competitive rock crawler & desert racer builds to its credit. They made me a better set of hoses than what WTOR supplied. Instead of welding on ram brackets they used my existing Synergy axle side damper bracket and a PSC clamp on the tie rod. We retained the stock pump with no issues, works fine. I added. Derale dual pass cooler which really brings down fluid temps and improves overall performance. The only issue has been keeping the system bled. For some reason it picks up air occasionally. I think it's the reservoir feed getting foam from trail sloshing. I may add a larger Howe reservoir. Bottom line, do it.
If you get a 1.5" ram, you can skip the pump. Personally, I want things to stay cool, so a cooler is a must and I like the res as it helps cool and keeps more fluid in the system.
I mean, if you wanted too, the ram is like $170. Tap your box, lines are around $120 all in. You could have a PSC system for around $300.
What about the stock steering gear box. Some say it is too weak. I have the synergy sector shaft brace already also.
I'm still thinking the WTO stage 3 with 1.5 cylinder. Add a cooler and I'm done.
I'm sure PSC is super nice but not going to 40's and it's not THAT bad as it sits. I have to think this will be just right.
Anyone have any compelling reason not to execute this plan?
[Tell me this, why should someone add hydro assist?[/QUOTE]
Too many times i was in situations where I couldn't turn the wheel because of rocks or a Prius in the way. If your in those situations then you will realize you need something more. If your not wheeling in those places stick with the brace kit. If your pitman arm breaks then that's just a bad day. I have seen the sector shaft go before a pitman arm, but hey shit happens. As far as the kit being cheap and to save your money, that's up to you. WTO makes a great product with outstanding customer service. PSC makes good stuff, but I have seen a lot of their boxes leak, they did send new ones, but they still leaked after spending 2k. One thing about WTO is they have you measure your steering throw so they can internally stop the ram from over extending. Im not saying PSC doesn't do that, but some have had to pull the PSC ram apart to add internal stops.
I strongly dislike the sector shaft brace kits. The only thing they do is increase the likelihood of failure. I've seen a couple boxes shear off the frame with no brace. That sucks, but the cost is 4 bolts to fix it. The braces put all the load onto the shaft itself. It's crazy how many broken shafts I have seen this year with people running the brace. In addition, every time this topic comes up, several more people chime in about how their steering box started leaking shortly after the brace was installed. Again, the load is all on the shaft and it trashes the seals and has a good chance of snapping the shaft clean off. In the cases I know first hand, it was not hard wheeling when it happened.
Go check out the price of a new steering box. Only the old delphi boxed can be rebuilt. Hydro assist is the only proper solution. Either you need it or you don't. The brace will cost you more than doing nothing.
For those who think the brace is a good idea, I am developing a muffler bearing brace that you cannot drive without. Provides the support the bearing is missing during hard driving. $150 intro price.
I have been running a PSC 1.75 8" ram with a Derale 5 pass cooler on the stock chinese box, stock pump, and stock res. The pump leaves a lot to be desired. Off road it is fine unless you punch it getting onto a dirt road and cant correct fast enough and end up driving into the woods looking like an idiot.
A buddy works in heavy equipment so he made me a set of lines, the cooler and fittings ran me about $50, and the ram was $200 something. I am very happy with it considering I only have $300 in it. Tapping the box is extremely simple. If you can use a drill and a tap and have a vice, you can do it.
