Regear front and rear diffs?
Old Mar 4, 2008 | 06:28 PM
sryzfr6's Avatar
Default Regear front and rear diffs?
I am going to install a 4.88 ring and pinion gear in my rear diff on my brand new 08 Unlimited X that has an open rear with the stock 3.21 gears.
Do I need to regear the front diff as well? Do I need to change the carrier?
Thanks. I'm a newbie to Jeeps.
Old Mar 4, 2008 | 06:36 PM
drojk's Avatar
Only if you like your transfer case... Yes, you must do both ends or the results will be a disaster.
Old Mar 5, 2008 | 07:36 PM
dpoelstra's Avatar
Why would it be a disaster if he did one end at a time?
You can do one axle at a time, but if you have different gears in each end, just do not ever put it in 4wd.
I know guys who have had to do things a bit at a time and could nto hold on to money, so when they had it, they got one step at a time done.
Old Mar 5, 2008 | 07:38 PM
Piginajeep's Avatar
unless you remove the front DS, your gears are still going to be spinning,,,
Old Mar 5, 2008 | 07:43 PM
Piginajeep's Avatar
Originally Posted by 2k2wranglerx
they're still spinning even if you do have your driveshaft in.
but your Tcase flanges will spin at different speeds.
DO NOT PUT IT IN 4WD if you do this!!!
right, remove the front driveshaft, problem solved
