Regearing ??????
Old Oct 30, 2011 | 12:54 PM
Jknewbee's Avatar
Default Regearing ??????
Have just regeared my 08 X to 4.88 gears with 35" tires. When i drove it stock I was in 4th gear from 40 to 60, 5th from 60 o 75, and 6th from there on out. But now I reach 5th gear at 50 mph. Does this seem right? I am still getting use to driving stick because this is my first manual car. I am shifting each gear around 3100 rpm is that even right? It seemed to be right when it was stock. Any help would be great
Old Oct 30, 2011 | 12:59 PM
hagausaf's Avatar
did you re-program with a Procal/Superchips for the new gears/tires? That helped me out tremendously after new gears and tires
Old Oct 30, 2011 | 01:02 PM
Jknewbee's Avatar
Yeah I have with super chips programmer!!! When you are going 50 mph what gear are you in????
Old Oct 30, 2011 | 01:04 PM
Cdyspeed's Avatar
I shift a lot lower than 3100 I shift around 2 or 2500 sometimes
Edit: I will say I drive like a grandma to save on gas haha
Old Oct 30, 2011 | 02:26 PM
shaggy591a's Avatar
Veteran: Navy
Yeah I don't shift until 2000-2500 rpm also.
Old Oct 30, 2011 | 05:55 PM
Cosmo jk's Avatar
Shifting around 2000 to 2500 here as well 3100 is pretty high
Old Oct 30, 2011 | 07:59 PM
jesse0376's Avatar
I always shift around 3-3200
Old Oct 30, 2011 | 08:46 PM
jeeeep's Avatar
that's about right- since you changed to 4.88's you will hit your shift points faster because you're hitting higher rpms quicker than when stock and loose some top speed but will gain more in the lower gears = great for off-road at the expense of freeway top speed
Old Oct 31, 2011 | 04:47 AM
jpkjk's Avatar
Who makes the gears ? Need to regard myself an there's so many options.
Old Oct 31, 2011 | 05:22 AM
Delux2769's Avatar
I shift between 2000-2200, But I'm a broke 21year old college student that drives like a grandpa. Helps to save on the $$$ given away at the pump. I'll edit later today with my MPH of shifting.
