Regearing question
ok4wd.com/
Last edited by wayoflife; 06-19-2011 at 06:32 AM. Reason: please do not post direct links to nono-sponsors
Well I wasn't planning on doing it myself but I don't think I would have any problems with it. I am a Georgia power mechanic so I have been to school and have plenty of experience in rebuilding gearboxes on equipment in the power plant. But thats not the issue here I was just asking what all I really needed to look for. For instance do I really need an overhaul kit? the jk doesn't have but 3500 miles on it now.
it is not for the casual wrencher!! I agree that the fun of a jeep is doing things yourself.... like I said earlier...i did my on lift...bumpers...on board air.. and much more.... this is not one... I wouldnt even let most mechanics do it unless they have regeard several jks...not even just other gears... I want someone who has done jks
I really don't understand why people are soooo afraid of these. The learning curve on this task is so sharp, that I think it's too beneficial to pass up. There are a ton of little things to know that make the job easier, so talking to someone who KNOWS what he is talking about is a must, but it's not a doomed task. I bought my Jeep with the gears in it, installed PROFESSIONALLY by a certain well known parts supplier. They didn't last me 2 weeks. I blew up my front differential, and did a lot of reading on wear patterns and whatnot and determined they were not set up correctly. I looked at prices of having it done and decided I could do it almost 3 times with the cost of parts versus paying someone to do it, and then have first hand knowledge of the task. It's one of those baptism by fires, I think. Read read read read read, do it, maybe screw it up, or get it right, then you know all the questions to ask to make it easier the next time. It is actually really retarded how you have to set carrier bearing pre load, and backlash, wish the designers of these axles would have put just a little more thought into it. Anyways, knowing how to do this makes you pretty invaluable in the community, cause there is always going to be someone who wants to do it and learn how, and you can have a rough, working understanding. Just my two cents, I did mine, and glad I did. I was a first time go at this station.
sure sounds great.... You talked me into it... anyone want to volunteer their 35k Rubicon for me to give it an ole whirl?????
just assumed since the guy was asking what he needed...then he didnt need to try himself... just trying to offer helpful advise... as
i said before...im all for doing things yourself.. and if my was and old heap...then fire away!!!!
Give these write-ups a good read-through.
https://www.jk-forum.com/forums/show...8112-It-begins....
https://www.jk-forum.com/forums/show...?82262-Gearing
As far as regearing yourself or letting a pro do it goes - it is something that I will try eventually, just not while this is my only vehicle.
Spend the money get the rebuild kits. No matter what new bearings should always go in. Then there is no worries. When u build rears everything should always be fresh
That adds another dynamic, if mine was my only ride, I wouldn't have either.
Thanks for all the info guys, I have no doubt that I could do this myself but I have a good mechanic that does my work for very reasonable prices, so it isn't worth my time to do it myself. I have a very busy schedule and have too much other stuff going on right now to attempt it.
