Reinforcing rear trackbar bracket?
Old Mar 29, 2007 | 10:47 AM
greggradwohl's Avatar
Default Reinforcing rear trackbar bracket?
Can I just go weld some more metal on the bracket/axle? What is the recommended process; do I need to deal with any type of axle dis-assembly?
Old Mar 29, 2007 | 01:31 PM
Also, I assume the axle carrier is mild steel. Correct?
Old Mar 29, 2007 | 02:52 PM
duneslider's Avatar
Just don't use those extender brackets and you shouldn't need to reinforce anything. However, I guess you could just beef it up by welding on some more metal.
Bryan
Old Mar 29, 2007 | 04:02 PM
Renegade's Avatar
You should be able to weld to the axle tubes fairly easily. The differential housing is cast iron and does not easily weld.
Old Mar 29, 2007 | 05:18 PM
IGOFSHN's Avatar
Don't believe that. The extender brackets are a bad idea but that doesn't mean that the stock bracket is ok. If you have the chance, reinforce it.
Old Mar 29, 2007 | 05:19 PM
IGOFSHN's Avatar
Bryan
Old Mar 29, 2007 | 05:55 PM
Thats what I'm thinking.
Old Mar 29, 2007 | 06:01 PM
IGOFSHN's Avatar
We haven't seen it on JK's yet because they are so new, but I saw it numerous times on TJ's. Track bar brackets are not designed for the twisting and stress when Jeeps flex.
Docwinkle's Avatar
Im going to use 1/4" trianglular gussets on each side of the stock bracket to reinforce it. just grind all the areas to be welded too first and use a good mig or tig machine.
Old Mar 29, 2007 | 07:18 PM
Do you know how thick the axle carrier tubes are?
