Removal Help
Old Jun 4, 2016 | 12:58 AM
DJ1's Avatar
DJ1
Former Member
Originally Posted by Kerberos
Use a crescent wrench...
Fit it to the shaft just under the knob then smack the wrench with a hammer.
Short of a slide hammer, best method I've found so far.
Good luck.
Originally Posted by shabbernigdo
the method i used. just put some tape on the shaft so you dont scratch it up.
Same thing I did after I couldn't pull it off by hand because I knew I was probably going to give myself a concussion. That knob is a biiiiitch
Old Jun 5, 2016 | 05:51 PM
foxsat71's Avatar
Originally Posted by sa29560
Shift it into 4lo and pull it off.
Done.
I choked the tires, put trans in neutral, put XFR case in neutral as well, straddled the XFR case knob facing the dash, gripped the knob with my hands, and pulled straight up. I don't recall if I had the top off or not.
