Remove rear seats JKU?
Old Nov 11, 2016 | 03:13 AM
stevedolce's Avatar
Default Remove rear seats JKU?
How the heck ya remove the rear seats in an unlimited??
The ones in the back were easy to access, the ones to the floor barely move and I have no idea how to access the ones under the seat! I have tons of ratchets, breaker bars and a 1/2 inch impact wrench so tools aren't the problem.
Any tricks of tips??
Old Nov 11, 2016 | 03:27 AM
pbeabout's Avatar
IF I remember right, when you take the bolts out from the floor brackets at the front of the seats you can then lift the front of the seat up enough to use a long extension to reach the lowest bolts at the back. Here is an old thread that should help.
https://www.jk-forum.com/forums/jk-w...rite-up-44784/
Old Nov 11, 2016 | 05:52 AM
jadmt's Avatar
JK-Forum Ambassador
use a flex or wobble joint. it takes me about 10 minutes to remove mine.
Old Nov 11, 2016 | 08:21 AM
stevedolce's Avatar
Yep-that's what I ended up with. Took out the bottoms, flipped the seat up, took out middle, then folded the backs down and did behind the seats. Literally took 20 minutes. Stripped the jeep for a trip to the LineX shop!!
