Removing dash panel sides
Old Jun 28, 2011 | 02:01 PM
LeftyStrat's Avatar
Default Removing dash panel sides
I've spent the last hour searching the forum for the answer to this, obviously the google-fu is weak in this one.
I need to get into the dash to wire some windshield lights. I can't seem to coax those panels off without fear of breaking them.
Is the 2011 different than earlier models? What exactly hold the panels on?
Old Jun 28, 2011 | 02:07 PM
JEP THNG's Avatar
from what I have read, you turn the vent bezel 1/4 turn and it comes out. Then on the passenger side, you just reach in and push the side out. I will get a thread where it is better described in a min....
Combsn6's Avatar
just clips, use a small screwdriver and pop them out
Old Jun 28, 2011 | 02:08 PM
Croce's Avatar
I know the 2010/11s have a redesigned interior. but for my 09, I take out the side air vent, when its out try sticking your finger through there to popoff the side panel
Old Jun 28, 2011 | 02:10 PM
Combsn6's Avatar
the 2011's you dont' need to just open the door (if they are on and pop the side piece off
Old Jun 28, 2011 | 02:27 PM
LeftyStrat's Avatar
Thanks guys, I figured it out. I took some pics so the next person searching might find this.
ID:	176534   Click image for larger version
ID:	176535   Click image for larger version
ID:	176536   Click image for larger version
ID:	176537   Click image for larger version
Old Nov 9, 2014 | 02:38 PM
klawd07's Avatar
Thanks Lefty, you saved me a ton of time
Old Nov 9, 2014 | 11:07 PM
Mark Doiron's Avatar
A picture like this of every panel/bezel in the Jeep in one thread would be such a useful tool. Usually it's just a matter of knowing what's on the backside of the panel, and where it's located. Then you can safely pry and prod until it comes free with far less worry you'll break something. Special credit would be if each picture came with the part number of any special clips used to secure the panel.
