Removing Factory bolts!!
Old May 4, 2009 | 02:10 PM
Comicnut25's Avatar
Default Removing Factory bolts!!
Hey Guys i'm trying to install my windsheild fog lights and to use the mounts i have to remove the factory bolts located here.. any tips? i noticed they were in there pretty good!!
Name:	Jeep bolts.jpg
Old May 4, 2009 | 02:13 PM
09rubicon's Avatar
God himself put those bolts in there!! Actually they have loctite frome the factory (blue type), just use a big breaker bar and be very carefull not to strip them.
Old May 4, 2009 | 02:15 PM
RubiRascal's Avatar
I used a torx driver and ratchet on mine and had no problem getting them out. Not overly tight on mine!
Old May 4, 2009 | 02:24 PM
RedneckJeep's Avatar
All I used was a T-40 and a short handle ratchet.
Old May 4, 2009 | 02:30 PM
09rubicon's Avatar
Wow, mine were covered in so much loctite that the entire bolt looked blue from just below the head down. So far all of them have been that way; windshield corner bolts, center pannel just below the window, door hinge bolts, etc. I think my JK probably has about 15lbs of loctite throughout it.
Old May 4, 2009 | 03:39 PM
paramaniac's Avatar
i have one of those multi-bit fold up torx sets and had no probs getting mine out when i installed my congo cage
Old May 4, 2009 | 03:46 PM
greenamphibious's Avatar
wrap the ratchet in a hand towel so if it slips of you don't screm your hood up
Old May 5, 2009 | 09:09 AM
Comicnut25's Avatar
Had to use a breaker bar and i wrapped the handle Thanks for the quick responses everyone my jeep appreciates it!
