Removing little orange lights under headlights
Old Apr 24, 2012 | 03:10 PM
Rebel3MJK's Avatar
Default Removing little orange lights under headlights
How do I do this? I can unplug and get the bulb out, but how do I get the orange casing out? Tia guys!
Old Apr 24, 2012 | 04:02 PM
JK_R&D's Avatar
I feel you on this one. A buddy showed me the trick. The first time your better off to take off the whole grill so you can see what you need to get at. Pull the plastic pins off the top of the grill, should be six. Twist the marker bulbs out, and just pull the grill off. When you flip it over, you will see that there are two tabs holding the light housing on. Just push them in and they pop right out. Hope this helps!
Old Apr 24, 2012 | 04:39 PM
Rebel3MJK's Avatar
Thought I might have to remove the grill... Thanks for the reply.
Old Apr 24, 2012 | 04:41 PM
rinkishJK's Avatar
U can prob pop them out with the grille installed by reaching through the wheel well and pushing the release tabs on the back and pop em out the front.
Old Apr 24, 2012 | 04:46 PM
AV8RS3V3RN's Avatar
Find a product manual for replacing them with after market ones...it will no doubt give you step by step directions in how to get in there. I found a decent set of instructions when I did mine by doing a Google search.
