removing spacers help
Old Mar 11, 2017 | 09:16 AM
snytribe's Avatar
Default removing spacers help
Had a lug on one of my Poison Spyder 1.5" spacers at Discount tire while getting tires rotated a couple of days ago. Checked them today to see if I could fix them and found that a second one was broken. After some work I got the spacer off. Trying to get the other rear one off, but it is not moving at all. Any suggestions. Also, I'm getting brakes done in two weeks can I leave the front spacers on unroll then?
Old Mar 11, 2017 | 09:46 AM
jadmt's Avatar
JK-Forum Ambassador
take a paint scraper and wedge it between the hub and the spacer and give it a wack with a mallet and they will come off.
Old Mar 11, 2017 | 10:00 AM
casamtb's Avatar
Heat. Use a propane torch to get it up to 300 degrees or so. Then like the other person said, use a paint scraper or wood chisel to pop it off. Put anti seize paste on it before u put it back on. It will take longer to heat it than u think.
Old Mar 11, 2017 | 10:05 AM
snytribe's Avatar
Thanks, that did it. Do I need to take the spacers off the front? Or can I wait two week?
Old Mar 11, 2017 | 10:22 AM
cjnomo's Avatar
There wouldn't be any mechanical probs with you doing this, but it'll look funny.
Old Mar 11, 2017 | 10:32 AM
snytribe's Avatar
I really like the look of the spacers. Should I be concerned that two lugs snapped. Or do I try a different brand of spacer.
Old Mar 11, 2017 | 10:38 AM
Potato Potato's Avatar
I would suggest buying new spacers.
I really like my spidertrax spacers. I have had zero issues after about 35k miles and multiple tire rotations.
Old Mar 11, 2017 | 10:58 AM
Ajkaz's Avatar
Do nut run them with broken studs, you should be able to replace the studs, check poison spyders website for replacement studs.
Old Mar 11, 2017 | 11:08 AM
snytribe's Avatar
I emailed poison spyder Wednesday and have not heard back from them. I could not find anything on their web site. I don't think they make them any longer. Maybe they have had a lot of trouble with them. I will try a different brand
Old Mar 11, 2017 | 11:13 AM
jadmt's Avatar
JK-Forum Ambassador
just press the broken stud out and replace with new stud. Tire shop should do it for you.
