Removing steering stabilizer
Old May 9, 2008 | 11:12 AM
melliscj's Avatar
Question Removing steering stabilizer
So I am in the middle of removing the stock steering stabilizer. I remove the bolt from the tie rod bracket fine. Whe I go to remove the bolt holding on the other end closest to the passengers side tire, the tie bar is in the way. So how do I get the bolt off?
Old May 9, 2008 | 11:17 AM
CrunchyOatmeal's Avatar
turn your steering wheel to the left and you should be able to get the bolt out.
Old May 9, 2008 | 11:32 AM
RedneckJeep's Avatar
If the front end sits REAL low like mine did, you won't be able to get it off turning to the left. I had to just jack mine up until the tie rod was out of the way.
Old May 9, 2008 | 11:51 AM
Dustoff '68's Avatar
Make sure you mark where the braket is currently mounted (the inboard part of the stabilizer) so you know where to put it if you install a new stabilizer...use a crayon/wax pencil.
Old May 9, 2008 | 01:39 PM
melliscj's Avatar
Sweet. Thanks for all the help. Woods relocation bracket is in along with the Skyjacker steering stabilizer. Looks good, works good. Putting them in was pretty straightforward except I am a big guy with big hands and it was a pretty tight fit. Oh well. Not the first time I busted up my knuckles.
