Replacement Jack
Old Jan 20, 2015 | 04:36 AM
rgincajun's Avatar
Default Replacement Jack
Morning guys,
I bought my Wrangler used and it didn't come with the emergency jack or other pieces that would normally come with a stock jeep for roadside emergencies. I've used a scissor jack from Harbor freight(broke on first time using it) and now have a big floor jack just moving around and taking up space.
I thought about getting a stock used one off EBay, but they seem overpriced. Also, I have a 2.5 inch lift and 35's, so I'm unsure a stock jack would even work if/when I needed it.
Any recommendations? I have stock bumpers, so Unfortunately no hi lift jacks. I'd really like a jack that fits in the stock storage space under the cargo tray and preferably a hydraulic jack... I realize it's a lot to ask, but I figured if anyone knew where to go or had a slick solution, it be all of you.
Specs- 2012 2dr Jeep Wrangler. 2.5 inch pro comp lift, 35" Federal Couragia tires, 18" Pro Comp Wheels.
Thanks for any advice or help ya'll can provide!
Old Jan 20, 2015 | 04:52 AM
CJ7nvrstk's Avatar
Vet Army
Originally Posted by rgincajun
Morning guys,
You could check a local salvage yard for a jack.
If it doesn't get you up high enough to change a tire, you could always take a few 6" pieces of 2x6 and stack em to use as a base to get you up higher. They also word well in situations where your jack would otherwise sink into the jacking surface, soft sand.
Old Jan 20, 2015 | 06:49 AM
phantom lord's Avatar
Aev jack base and OEM jack worked well for me on my last jeep. I had a 3" lift on it with 35's.
