Replacement Roll Cage
Old Jul 22, 2007 | 08:30 AM
Robar's Avatar
It is bolted.
http://www.northridge4x4.com/proddet...prod=RH-JKCAGE
Old Jul 22, 2007 | 09:20 AM
justrok's Avatar
Did you make the padding yourself?
Old Jul 23, 2007 | 03:52 PM
RUBICONPOOR's Avatar
PhilD, You did a great job on the install. I just bought on and I will be installing this on Thursday. I had one on my TJ and I know you have to trim the a-pillar garnish, how hard was it? The door surrond also has to trimmed, what did you use for that? any info will help. Rockhard does make some great products.
Thanks Dane
Old Jul 25, 2007 | 10:09 AM
justrok's Avatar
Originally Posted by PhilD
Not difficult, although a little time cobsuming as you have to trim a lot of it.
Do you mean the window frames for the soft top? That was easy, just used a dremel and took the end of it off.
I'm overdue on taking some pics of the various bits and will try and do so later today.
Great, I still can't figure out how it mounts at the cowl and at the top of the windshield. Also, do you think the cage makes it more difficult to remove the "freedom top".
