rim and tire help
Old May 10, 2010 | 08:03 AM
REDLINE217's Avatar
Default rim and tire help
im looking at putting 35" tires on my 4 door jeep and also getting a new set of rims but i don't fully understand the tire and rims sizes. if anyone can help me understand the rims and tire sizes that would be greatly appreciated. and what would look/fit/ride the best that would be awesome. this jeep is also my Daily driver
Old May 10, 2010 | 08:05 AM
crcjk's Avatar
Default Re: rim and tire help
There are a ton of threads on this, so try a search. 17in are probably your best bet for 35s. Good luck
Sent from my Droid using Tapatalk
Old May 10, 2010 | 08:06 AM
JayhawkJeep's Avatar
Veteran: Navy
Here is probably the best place to start your research.
https://www.jk-forum.com/forums/show...274#post211274
Old May 10, 2010 | 08:08 AM
REDLINE217's Avatar
so do you think a 15in rim would probably be to small or wouldn't look right ?
Old May 10, 2010 | 08:14 AM
REDLINE217's Avatar
cool thanks that helped alot
Old May 10, 2010 | 09:31 AM
spinlock's Avatar
The only problem with some 15" rims is a slight interference with the brake calipers. There are many rolling on 15" wheels.
Old May 10, 2010 | 05:16 PM
REDLINE217's Avatar
so i should just run 17's to be safe ?
Old May 11, 2010 | 03:57 AM
crcjk's Avatar
Since it is a dd, I would suggest 17s. If you were rock crawling on a reg basis, then 15s might be better. A 15 on 35s will probably cause more balance issues and will definitely create more heat on the tires. There are many people on the forum running 15s so maybe they can correct me if I am wrong here - my 2c
Sent from my Droid
