rim width range????
Old Jul 3, 2009 | 06:17 PM
tento0929's Avatar
Default rim width range????
is it safe to use a tire that the rim width range goes from 8.5 to 11.5 on a 7.5 wheel?????
Old Jul 3, 2009 | 06:23 PM
bluerubicon08's Avatar
It is not recommended, especially if you air down for off roading.......you are sure to pop a bead that way
Old Jul 4, 2009 | 07:57 AM
tento0929's Avatar
ok so if i put any of these tires on stock wheels the only problem will be airin down too much??? or theres somthing else i need to know??
what do you think is the max air down i can do to not have a problem?
thanks
