RIPP Header Help
Just received my RIPP headers, but doesn't look like there was any hardware with them or instructions. Is there supposed to be any hardware that comes with? I saw from searching that I need to re-use the manifold gaskets, but what size screws/bolts are needed for the ball/socket connections?
I just received mine and i had a couple of little bags that came with it. There should be a clamp, 4 long bolts and 12 replacement bolts for the header install. Along with instructions. Call RIPP they were very helpful with my install. Also look into the HP-2 resonator, its super loud.
Thanks. I did get the HP-2 to go along with the mbrp exhaust. Did you go with the Diablo Tuner as well? I was going to try and re-use the Hypertech.
