RK 2.5 Max Travel - Will TF Exhaust Spacers Be Enough
Getting ready to lift a '12 JKU manual and just pouring over my options here.
Wondering if any one who has the RK 2.5" Max had had ANY issues with the front drive shaft rubbing despite having the TF spacers installed?
Note: This is on a manual.
Thanks.
Thanks.
I have the rk 2.5" max travel and tf spacers. My driveshaft has not hit the exhaust so far. But I have not yet fully articulated the suspension with the sway bar disconnected on an actual trail ... 2d jkr 6 sp.
JK-Forum Founder
being that you have a 12, the problem would be the same regardless if you have an auto or manual. unless you install crazy longer shocks than what is recommended, you will be fine with this setup.
