Rock krawler 2.5 bump stop problem
Just installed a rk 2.5 max travel and the rear lower passenger track bar bracket is hitting the bump stop ...jeep is tracking fine but has not been aligned yet could this be the problem or something else ????
because on the passenger rear the bracket is located on the frame side while on the drivers side the bracket is on the axle side.Is this a typo? Or do you mean:
It's hitting the drivers side bracket
It's not the track bar, but you meant to say sway bar links
