Rock krawler 2.5 bump stop problem
Old Aug 25, 2012 | 07:43 PM
krzfirefighter013's Avatar
Default Rock krawler 2.5 bump stop problem
Just installed a rk 2.5 max travel and the rear lower passenger track bar bracket is hitting the bump stop ...jeep is tracking fine but has not been aligned yet could this be the problem or something else ????
Old Aug 26, 2012 | 01:26 AM
Bump for help
Old Aug 26, 2012 | 02:48 AM
EzK's Avatar
EzK
I'm trying to picture what's happening here and can't. The rear axle should be aligned after installing the tb bracket if the adjustable rear tb is set to the same length as stock.
Pics?
Old Aug 26, 2012 | 04:10 AM
damon.l's Avatar
ya, im not getting it either. i had no issues with my rears contacting on my 2.5 max travel. not saying you are not but i cant see how you are.
pics def would help.
Old Aug 26, 2012 | 11:24 AM
aldaman's Avatar
Originally Posted by krzfirefighter013
......the rear lower passenger track bar bracket is hitting the bump stop ...
pics would definately help. I am a bit confused because on the passenger rear the bracket is located on the frame side while on the drivers side the bracket is on the axle side.
Is this a typo? Or do you mean:
It's hitting the drivers side bracket
It's not the track bar, but you meant to say sway bar links
