Rock krawler quick disco install help????
Old Jun 14, 2013 | 02:00 PM
backwoods-jeep's Avatar
Default Rock krawler quick disco install help????
EDIT. hey guys what are the small black tabs provided along with rock crawler quick discos i belive there points to put you discos when disconnected but im not shure were they go
Old Jun 14, 2013 | 02:40 PM
n3tfury's Avatar
Longest sentence ever?
**free bump**
Old Jun 14, 2013 | 02:42 PM
JKred's Avatar
One end bolts to your sway bar (non disconnecting end) the other bolts to your axle tabs. I really don't know how else to explain it, it's pretty easy/straight forward. Pics would be great....
They should be much longer than stock. Your sway bar should sit level if not pitched up a little bit.
Old Jun 14, 2013 | 03:47 PM
sorry bad punctuation habits picked up threw texting alot. and axel tabs, if youd have just a reference pic i could go from there. im very mechanically inclined just not with suspension systems. this is my first jeep ive ever owned and im just now after a year beginning to work on it more. my last vehicle was a 79 f 150 i did a full restore on so theres a bit difference in working on a 08 jeep
Old Jun 14, 2013 | 03:53 PM
ok i got this i figured it out
the small black tabs that came with it i believe bolt somewhere for when your disconnected. but were........
Old Jun 14, 2013 | 04:45 PM
mcmahonbj's Avatar
Didn't come with instructions?
Old Jun 14, 2013 | 04:49 PM
nthinuf's Avatar
If you can't get to the install sheet on their website, try quadratecs. There will be a link from all of the RK suspension pages, just find one with those links.
19. Install the front sway bar disconnects as shown below.
For the top mount use the supplied ½” x 2.5” bolt, .595” long spacer, and nylok nut to make the connection. Please note the shoulder of the spacer goes against the sway bar
itself. For the bottom connection attach the ½” x 2.0” long bolt with cross drilled hole to the factory sway bar link bracket. Secure the bolt with the supplied ½” jam nut. For connecting the bottom end of the sway bar link to the bottom bolt there are two options supplied with each kit. If you do not have the automatic sway bar disconnect feature you can secure the bottom end of the sway bar link with the 2 nylon washers on either side of the rod end and secure it with the pin. If you do have the automatic sway bar disconnect feature you can simply secure the bottom rod end with the supplied ½” nylok nut. Please note: on some sway bars you may have to reem out the hole to ½” with a ½” drill bit.
Old Jun 14, 2013 | 04:56 PM
BeachJK's Avatar
Originally Posted by backwoods-jeep
hey guys got a set of quick discos for my rig finally off another forum member but they have no install instructions and im kinda lost because i have a 2.5 in lift and thats what these are for but there longer then my stock sway bar connects and theres some plate with them i tried using rock krawlers instructions on there sight but it wont open for me maybe this is a dumb question but i could really use the help
Does this help?
Old Jun 14, 2013 | 06:02 PM
mcmahonbj's Avatar
Originally Posted by BeachJK
Does this help?
Attachment 467993
At least I am not the only one that has that piece rusted, they need to change their material.
Old Jun 14, 2013 | 06:31 PM
ive figured it all out accept for were that little black metal goes
