Rock Rails
Purejeep Rock Rails or
Shrockworks Rock Rail
Need your help to make a decission. I like the the looks and design of shrockworks and also they are available in different colors BUT i like the underneath and onepeace design strength of purjeep rock rails.
I have to agree. When it comes to frame mounted rails, the Shrockworks are hard to beat. If you want a good set of body mounted rails, the same can be said about the PUREJEEP rails.
Is there a big difference in strength between body mounted and frame mounted? I still have my stock rubi rails and they are pretty gouged up and need to be replaced. I REALLY put a beating on them and would like the strongest setup to replace with.
WOL
Which one would you recommend. Body mounted or frame mounted i know the difference between them
but not sure which is better body or frame
