Rock and roll
Old Apr 2, 2013 | 06:05 PM
k.baker B.D.O.R's Avatar
Default Rock and roll
I'm looking for some ideas on how to fix a few things I'm having issues with first is the real top heavy feel of the jeep I have a 5.5 rk lift yes it's high but it almost drives like it has no sway bars on it but I does any ideas on how to fix it and the other is the steering is really jittery and seems to steer way to easy wondering of a way to damper it down
Old Apr 3, 2013 | 11:57 AM
Bump anyone
Old Apr 3, 2013 | 12:20 PM
snakeyes76's Avatar
HD sway bar (i.e Full Traction) might help. However, like you said, it's a 5.5" lift so top heavy is kinda normal
Old Apr 3, 2013 | 12:28 PM
rinkishJK's Avatar
What's your caster set to? Did u set your swaybar link lengths correctly? What size tires are u running? We need some more info. With that much lift u definitely want a front trackbar relocation bracket and a drag link flip to raise the roll center of the jeep. Did u buy a complete kit?
Old Apr 3, 2013 | 12:32 PM
jk.bushwacker's Avatar
lower that shiz unless you wanna add nosebleeds to that list
Old Apr 3, 2013 | 12:37 PM
Tonka_yellow's Avatar
A stiffer sway bar will help if everything else is in check
Old Apr 3, 2013 | 12:52 PM
GJeep's Avatar
Your profile says 3.5" lift -- what lift have you got ?
You may want to consider the Full Traction CRC.
I have the same wheel size & 4" lift, and it made my Jeep steer better than stock.
Links:
https://www.jk-forum.com/forums/modi...c-link-174117/
CRC Link- higher speeds - YouTube
Full-Traction Suspension | Jeep JK CRC-Link Conversion Factory Axle
Old Apr 3, 2013 | 02:14 PM
I have a new jeep it has a 5.5 rock krawler lift
Old Apr 3, 2013 | 02:19 PM
I have the rock krawler drag link flip my caster is all good the sway bar links I need to check I'm running 37s I have a hard top for now I'm also curious about the jittery steering
Old Apr 3, 2013 | 02:25 PM
fredrok's Avatar
What is your caster, toe and camber settings? Which RK kit which would tell us what components you've upgraded? How much tire pressure and what tires? Really just need more info to accurately diagnose.
