Roof rack recommendations?
Old Dec 5, 2013 | 09:54 AM
Jeep4Snow's Avatar
Default Roof rack recommendations?
Now that winter is nearly here I'm getting my Jeep ready for ski season.
Previously I had a 2DR softtop with a Gobi stealth rack and a Thule cargo box for extra capacity. Before I outfit my 4DR hardtop with a similar configuration I wanted to see if anyone had any luck with less costly options? Like the Congo cage, Garvin or Thule bars / feet?
Old Dec 5, 2013 | 11:14 AM
SaFFFari's Avatar
I'll post a picture when I get off work. I am running the body armor rack (craiglist $250 If I recall correctly) and Yakima power hound I removed from my old silverado ($100). Thinking of selling my power hound and buyin the Thule holder that holds them at a 45deg angle though. I have a cargo basket (cheap knock off) that I would like to keep up there for my snow gear bag (boots, gloves and all that other good stuff), however I can't utilize it when using the power hound cause it's too long. I'll post pictures after work
Old Dec 5, 2013 | 11:21 AM
etl330's Avatar
I vote for this one http://www.youtube.com/watch?v=Tz-Zw5cyBEo
Old Dec 5, 2013 | 11:29 AM
SaFFFari's Avatar
Here's a picture I dug up from my old set up. I had i-bolts going thru my hard top with silicone and washers. Never had leaks. Had the same power hounds bolted directly without a rack. Downside to this was in order to hold 4 boards up there was to remove the bindings on the boards that were facing down. Here's is a thread u should browse for more ideas "Snowboard rack pic request"
ID:	514705   Click image for larger version
ID:	514706   Click image for larger version
ID:	514707   Click image for larger version
Old Dec 5, 2013 | 11:38 AM
tklein42's Avatar
Garvin Wilderness Racks
Definately take a look at these racks. Im in a similar situation as you and to tell you the truth, this is the best looking rack i could find with great functionality. If not, close to it. Please do post if you find something better. Ill be throwing down the cash soon!
Old Dec 5, 2013 | 04:09 PM
Saharaunlmtd's Avatar
You already spoiled yourself the first time around. May as well do it again.
Old Dec 5, 2013 | 04:35 PM
SaFFFari's Avatar
What I now have is this..
My old power hounds are as wide as the basket, so I fit them both at the same time..
And these... Are what I want to go on both sides of the basket ..
