Which Rough Country Lift??
Old Feb 29, 2012 | 09:22 PM
Chronotripper's Avatar
Veteran: Marine Corp
Originally Posted by jkfisher84
He said CAR!!!
Haha, I love how Jeep owners never call their Jeep a "car." Even when referring to a Jeep in Korean, you say "Jeep car" instead of just car.
Old Mar 1, 2012 | 03:46 AM
jkfisher84's Avatar
Originally Posted by ttechris
Thanks!
I won't make that mistake again, but hey... its late
Just messing with ya!
Old Mar 1, 2012 | 09:48 AM
JnT's Avatar
JnT
3.5" Series II has been ordered and I'm getting the adjustable track bar as well. Now comes the painful waiting time
Is it here yet? I cant WAIT for spring and summer to go play again!!!!!
Old Mar 1, 2012 | 10:47 AM
Croce's Avatar
Grats.When i ordered mine from the RC rep it arrived in only 3 days!
Old Mar 1, 2012 | 11:45 AM
JnT's Avatar
JnT
I'm in Canukistan though. Gotta get shipped from the states to the shop I'm buying it through then out to me. I'm hoping for less than a week but it might be longer if it gets held up in customs.
Old Mar 8, 2012 | 09:57 AM
JnT's Avatar
JnT
Originally Posted by Croce
Correct. If using the stock trackbar you would then want to use the drop pitman arm and the trackbar relocation bracket. If you have an adj trackbar, you wont use either one and just replace the stock trackbar with the adj one
Hoping too do his install tonight and I just want to clarify on the Pitman arm and track bar bracket. Am I reusing the stock ones or removing completely?
Old Mar 8, 2012 | 10:05 AM
snakeyes76's Avatar
good choice on the 3.5 - i have the 2.5 coil lift and find it a tad on the short side.
prob add the spacers eventually or just go straight 3.5
Old Mar 8, 2012 | 10:17 AM
Croce's Avatar
With the Adj trackbar. Use the stock pitman arm thats already on the Jeep. Dont use the trackbar relocation bracket. So pretty much just replace the stockt trackbar with the adj one and leave it at that (dont forget to adjust trackbar)
I would also suggest swapping out the 14mm stock trackbar bolts for grade 8, 3" long, fine thread, 9/16" bolts. Use either a stover locknut or a split lock washer on the back side and a grade 8 flat washer on the bolt head side.
https://www.jk-forum.com/forums/show...es-and-Wobbles
Also! When installing the lift. Do NOT tighten the control arms or trackbar until the jeep is sitting on all 4 wheels (so not on jack stands). Shake the jeep back and forth to settle everything, Then tighten the trackbar and control arm bolts
Old Mar 8, 2012 | 12:04 PM
JnT's Avatar
JnT
Thanks Croce!
Just the info I'm looking for! Now if only my parts guy would call and let me know it's in yet .....
Old Mar 8, 2012 | 01:12 PM
JnT's Avatar
JnT
ARRRGGGHHHHH!!!!! UPS only delivered one of the three boxes!!! Now I have to wait another day for the other 2 boxes
