Rubi locker quit. Question though
Old May 20, 2014 | 02:21 PM
GulfCoastJeeper's Avatar
Default Rubi locker quit. Question though
Have a rubicon 44 front with RCV shafts and new gears installed but the lockers not working. Can I upgrade to an ARB locker and keep those shafts and gears?
Old May 20, 2014 | 02:31 PM
mikeJKUR's Avatar
Did it stop working right after you had the shafts and gears installed?
Old May 20, 2014 | 03:50 PM
JKZinger's Avatar
You need to buy the 35 spline stub shafts for an ARB to work with RCV's
Old May 20, 2014 | 03:51 PM
nthinuf's Avatar
Gears yes, but an ARB would need 35 spline shafts. I think you can get a 30 spline OX locker for the rubi housings?
If the locker stopped working during the gear install, have them check the plunger position and the wires.
Old May 20, 2014 | 05:09 PM
dhughes's Avatar
Not sure about the arb but yes you can get the ox locker for stock spline count.
Sent from my GT-P5113 using Tapatalk
Old May 20, 2014 | 07:26 PM
. Shafts were there and had to change gears due to faulty axle seal and overheating the diff. When opened gears had chipped teeth. I think the locker had quit before then anyways.
Old May 20, 2014 | 07:27 PM
Does ox make air lockers or just those manual ones?
Old May 20, 2014 | 08:10 PM
Bear9494's Avatar
Ox makes a locker that can be activated via manual cable, air, or electric. Same locker, you choose how to activate.
Old May 21, 2014 | 02:40 PM
Thanks!
