Rubi shocks install.
Old Feb 9, 2014 | 07:05 AM
patjoedav19's Avatar
Default Rubi shocks install.
Hey guys, still kinda new to the forum so bear with me. I am in the process of buying rubicon springs/shocks (18/60) with 400 miles from another member and will be installing once it warms up. I own a 2012 sport with no suspension upgrades to this point. I understand I am going from stock to stock but I think I will get a slight lift from the setup. My main question is if there should be any concern for adjusting anything else (mainly thinking of brake line extensions). I know I will have to loosen suspension components and brake lines to do the actual swap but afterwards am I all set running everything else stock? I also assume my alignment will be ok afterwards, am I right ASSuming? Thanks guys.
PS I called the dealership for giggles to see what they would charge for the install alone.....take a guess at what the quote was, clue: I did laugh and hang up.
Old Feb 9, 2014 | 07:14 AM
jadmt's Avatar
JK-Forum Ambassador
stock parts will require nothing additional. Unless you checked you may have the same springs already as it is hit or miss what they come from the factory with. My buddys basic sport 4 door has 18/60 from the factory and mine had 17/58.
Old Feb 9, 2014 | 08:48 AM
jeepmojo's Avatar
Default he has a 2 door
they dont come with high numberd springs ! if you hear of another with some springs and shocks for sale cheap drop a pm thanks im in nh
also some pics after and before install
Old Feb 9, 2014 | 11:23 AM
jadmt's Avatar
JK-Forum Ambassador
check the want ads I just sold a set of front and rear 17/58 for $20 new take offs. I have a buddy that has some new 18/60's that have less then 300 miles on them. I do know that it cost me $about $40 to ship to Louisiana. so not cheap to ship.
Old Feb 9, 2014 | 03:27 PM
'11BronzeStar70th's Avatar
I posted my experience with this subject last month in the Stock JK section under "Rubicon Suspension vs Non-Rubi". Virtually no additional lift on my '11 JKU after the swap and I did it myself in about 3-hours in my garage doing one end at a time. Jack stands, a hydraulic floor jack, a couple scraps of 2x4, remember to slip the differential vent tubes off the fittings and pull the brake line brackets from the wheel wells so you don't tweak them at full extension. Pull the tires & wheels and Disconnect the saw bar links from the axle when you have the load off the suspension and the frame is on the jack stands. Unbolt the shocks and slowly lower the axle until the springs are loose. Be sure you get the spacers back in and the springs oriented the same as the ones you pulled out, jack up the axle and reverse everything you just did. Oh, you may need to slip the e-brake actuation cables out of their hangers for the rear. Double check the tightness of EVERYTHING you broke loose and that you put everything back in its place before you put the wheels back on. You will also probably have to do the front one side, then the other because of the offset pumpkin. Good luck!
Old Feb 9, 2014 | 04:40 PM
Thanks man! That's the info I was looking for.
Old Feb 9, 2014 | 04:42 PM
Excuse my ignorance but differential tubes? Is this just a hose you pull off and reconnect after?
Old Feb 9, 2014 | 05:14 PM
HeyBob's Avatar
Yes it's just a hose. You might also look up the install directions for the 2.5" teraflex lift. It will give you an idea what to loosen up and what to remove in order to squeeze in your springs. My first time with rubi springs took 4hrs. I've done 3 sets now slowly moving up in height. My last set tool about an hour. Good luck! Also you won't need an alignment there isn't anything that will get adjusted except your steering wheel. You can recenter that with simple hand tools.
The only tool you will have to buy (especially if you plan on more suspension mods). Is a good torque wrench. You will have to tighten bolts to spec and hand tight doesn't cut it for track bars. It's a good way to get death wobble.
Old Feb 9, 2014 | 05:42 PM
Thanks man
