Rubicon locker question
Old Jul 17, 2015 | 08:45 PM
WkFish's Avatar
Default Rubicon locker question
Right so I recently purchased a dana 44 rear with factory Rubi locker and I am wondering before I swap it in do I have to wire the locker? Also how should i go about wiring this locker I do not have a spod so I'm looking for the cheapest and easiest way to wire this in. Thanks guys!
Old Jul 18, 2015 | 03:32 AM
14Sport's Avatar
I suggest a relay...
Old Jul 18, 2015 | 05:28 AM
TheDirtman's Avatar
You don't need the relay, the locker is 12v. You can simply just wire any on off switch to the axle. No reason to add complexity to the situation.
Old Jul 18, 2015 | 05:50 AM
OH9JK's Avatar
JK-Forum Ambassador
I agree, keep it simple! The draw on that circuit is only around 5 - 8 amps. Just put a fuse inline for safety.
Old Jul 18, 2015 | 06:24 AM
WkFish's Avatar
Alright so another question for you all, the axle I purchased has the spring perches welded 5 degrees forward to correct for lift. With his setup what would be the best size lift to go to? I was thinking either a bds lift or AEV at their 2.5" which should net me around 3.5" with a 2 dr correct?
Old Jul 18, 2015 | 06:34 AM
PsychoCupcake's Avatar
An AEV 2.5" lift should get you exactly that, assuming you have aftermarket bumpers or other items that weigh the vehicle down. I have a 2 door and got exactly 2.5" with a poison spyder front bumper, winch, Ace rear bumper and tire carrier with a 35.
So without the extra weight, yes you can expect to sit a little higher.
Old Jul 18, 2015 | 06:37 AM
14Sport's Avatar
I use relays for anything over 5 amps but to each his own.
If you don't want to use a relay then you could wire it like this (accessory being locker). Just make sure everything is rated properly. You could use a tap-a-fuse off the TIPM instead of going to the battery if desired.
