Rubicon locker wire up
Old Jun 10, 2014 | 01:26 PM
FlexyJK's Avatar
Default Rubicon locker wire up
I just got a Pro Rock running the Rubicon locker and wondering the best way to hook up the switch. I have searched and saw people say to buy a harness from Mopar for like 150 bucks. I dont really want to do that. So if anyone knows of a write up or has done this and can help me out i would greatly appreciate it. Also which plugs do what on the axle. I see 2 and im unclear which is which.
Old Jun 10, 2014 | 06:05 PM
FlexyJK's Avatar
Anyone?
Sent from my SM-N900V using Tapatalk
Old Jun 10, 2014 | 07:44 PM
Rebar-7's Avatar
Well you need to find a connector plug that will work . One plug is for the actuator the other is just for light to show it's locked. Basically just wire actuator to a relay to a switch...thinking...
Old Jun 10, 2014 | 07:56 PM
D_engel's Avatar
this is the most thorough write up I've come across
Y90's Rubicon Axle Swap Write Up
Old Jun 10, 2014 | 08:14 PM
FlexyJK's Avatar
Awesome. Thanks for this. I'm going to try and do this tomorrow/Thursday.
Old Jun 11, 2014 | 03:58 AM
Invest2m4's Avatar
I used the rugged ridge a-pillar switch pod when I wired mine. Looks stock and made things a lot easier. Wires can be fed from the engine compartment into the a-pillar. There is a 12v wire there that can be tapped to power the switches. I ran locker power wires to relays and the indicators directly to the locker. Ran a 15 amp fuse before each relay (kept them separate in case one goes, I still have one that works).
I have a diagram I made I could send. My friend helped who is an electrical engineer in the auto industry.
I personally recommend buying the $95 harness and cutting the plugs off. The lockers have some gremlins and you'll want to be able to disconnect them.
Old Feb 21, 2015 | 08:29 AM
Krawlersaur's Avatar
Thread revival. Invest2m4, can you pm me that info. I'd be very interested in that diagram.
Old Feb 21, 2015 | 02:02 PM
Invest2m4's Avatar
Yeah, I'll dig it up tonight. It's really an easy project. I stressed over it and then had a friend help who is an electrical engineer in the auto industry. Turned out that it was as easy as people had said.
Old Feb 21, 2015 | 02:09 PM
Awesome. Thanks man!
Old Feb 21, 2015 | 02:36 PM
14Sport's Avatar
In case Invest doesn't find it, here is a schematic. If you put a LED inline as shown in the indicator circuit you will be able to tell when the locker is still engaged even after the switch is shut off.
Name:	Rubi Locker Wiring.jpg
