Rubicon locker wire up
Alright, found it. Mine is a little different as I had a few specifics.
1. I wanted to use a Cotura II switch so that I had a light for the locker indicator.
2. I wanted my switch set up so that when I powered the locker the top main light came on and when the locker engaged the lower light came on. I am glad I did it that way as the Rubi locker is not always quick to engage or disengage (I don't want to find out halfway up a nasty climb that my lockers weren't engaged when I expected they would be).
I used the Rugged Ridge A-pillar pod and found a 12v connection running right there, so it was easy to wire. I see people pulling the dash apart for a 12v lead, which is crazy. This is also intended to be completely free of the JK electronics.
That's pretty cool using the lower light for engaged.
Wouldn't work for me though because my lower lights are all connected to my dash lights but definitely a good way to do it otherwise.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=598348"/>
Alright, found it. Mine is a little different as I had a few specifics. 1. I wanted to use a Cotura II switch so that I had a light for the locker indicator. 2. I wanted my switch set up so that when I powered the locker the top main light came on and when the locker engaged the lower light came on. I am glad I did it that way as the Rubi locker is not always quick to engage or disengage (I don't want to find out halfway up a nasty climb that my lockers weren't engaged when I expected they would be). I used the Rugged Ridge A-pillar pod and found a 12v connection running right there, so it was easy to wire. I see people pulling the dash apart for a 12v lead, which is crazy. This is also intended to be completely free of the JK electronics. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=598348"/>
