Rubicon SB disconnect problem
Old May 26, 2013 | 08:31 PM
amel22's Avatar
EVO no limits manual disconnect or a home made one
Old May 26, 2013 | 09:07 PM
amel22's Avatar
Old May 26, 2013 | 10:56 PM
jeeeep's Avatar
Originally Posted by s2kako
Added a Teraflex 2.5 inch coil lift. I have longer sway bar links and take it offroading. The Sway bar disconnected with out a problem, but it's not reconnecting anymore. I've drive about 20 miles already and the light just keeps flashing... Any ideas?
have you tried disengaging it while on the flat? disengage and the re-engage, sometimes it takes a couple of times
Old May 27, 2013 | 01:01 AM
s2kako's Avatar
This is what I'll be doing after I get it reconnected. No more messing with the e-disco. More hassle than anything at this point
Yes I have. But I'll mess with it some more. I just want it to reconnect than ill get manual disconnects and call it a day.
Old Jul 15, 2013 | 09:55 AM
Tuto's Avatar
We have a 2010 jku Rubi Auto. When the sway bar ligth flashes it means that the Sway Bar still connected. When the light stays ON it means that the sway bar IS disconnecrted. That how it Works in our jeep. Also, you have to be in 4 Wheel drive to for the Electric disconnect to work, unless you have a programmer to over ride the Factory Settings.
Have you check the plug on the E disconect(electric motor) ?
Like Unpluging it and pluging again ?
Old Jul 15, 2013 | 10:11 AM
Jeepstercanada's Avatar
Same thing happened to me, I disconnected the battery for half an hour reconnected it and it was all good haven't had a problem since
