Rubicon Susp. stuff on a sport s????
Old Nov 7, 2011 | 04:53 PM
jvoisine's Avatar
Default Rubicon Susp. stuff on a sport s????
I have a 2012 JK Sport S Unlimited. My question is, What would i gain by putting all stock Rubicon Susp. stuff on my jeep. Shock, Springs, and all the other goodies.
The most I plan on doing to it is 2.5 teraflex, but that won't be till i need new tires.
thank you
Old Nov 7, 2011 | 05:13 PM
MoTec's Avatar
thank you
The rubicon shocks are gas charged and are reported to give a better ride. The shocks might give you a little lift. If you have a 2dr and go with 4dr spring you should gain at least an inch of lift. Other than that there isn't much in the way of differences unless you are talking about replacing axles and such.
Old Nov 7, 2011 | 05:19 PM
jvoisine's Avatar
thanks for the info.. Now I need to find out if a 2011 rubi Unlimited will fit a 2012 jku sport.
Old Nov 7, 2011 | 05:24 PM
Freewill's Avatar
Rubi springs won't make much difference on a JKU because the Unlimited already has higher rated springs than a 2-door. Still, if you can get some 18 or 19 fronts and 59 rears it would offer a bit more height and a nicer ride. They are really easy to swap so the effort is no big deal. Check the numbers on your existing springs to make sure the rubi springs actually have higher numbers.
Rubi shocks are gas charged just like the sport shocks, but the rubi shocks are matched to the rubi springs and offer better ride control. The shocks don't lift anything - that's done by the springs - but the rubi shocks are larger diameter and heavier duty. And they are red
Old Nov 7, 2011 | 05:32 PM
jvoisine's Avatar
thanks freewill, do you know if 2011 will work on a 2012?
Old Nov 7, 2011 | 05:37 PM
Robar's Avatar
Yes, they will interchange.
Old Nov 8, 2011 | 05:07 AM
azyjjk's Avatar
I thought only the Rubi shocks were gas charged?
Old Nov 8, 2011 | 09:08 AM
Freewill's Avatar
You are correct. I thought all the OEM shocks were gas charged. Just checked my Sport take-offs and they are not gas charged.
All the more reason to swap for rubis.
Old Nov 8, 2011 | 09:45 AM
KDBinAZ's Avatar
My '09 sport (X) shocks were gas charged? I think all JK shocks are gas,
they just compressed at approximately half the pressure needed for the rubi shocks
Old Nov 8, 2011 | 10:35 AM
Freewill's Avatar
That's what I thought, and possibly the '09 X came with a gas shock, but the shocks from my '11 Sport have no pressure in them.
I thought they were under pressure because they have been lying on my bench all stretched out the way I took them off a few weeks ago - but before my earlier post I went out and pushed them to their shortest position and they just stayed that way. No pressure at all. A gas shock would have rebounded to maximum length right away. They were, like, 3 months old and 1500 miles when I took them off.
