running 33's
Old Jun 28, 2010 | 11:59 AM
mainejeeper's Avatar
Great input everyone. Thanks!
Nathan
Old Jun 29, 2010 | 09:30 AM
Ryan L's Avatar
Superchips Flashpaq will fix most issues with 33s. There's no reason to ride around in a modern vehicle with a screwed up speedo.
Old Jun 30, 2010 | 05:01 AM
shogunn's Avatar
Default running 33's
Originally Posted by redx08
You could go with teraflex leveling kit for about the same price as a body kit. I think it would look better too. I am just not a fan of body lifts.
Agreed. I've got the tf leveling kit. Easy install and looks way better than a body lift.
Old Jun 30, 2010 | 10:17 AM
Are you guys running the TF kit on 2 or 4 doors? Standard or automatic trans? I have a 2 door auto. I've heard of front drive shaft problems with any lift.
Old Jun 30, 2010 | 10:22 AM
RevyJKU08's Avatar
Anything over 3" of lift you will have to start looking at a new front Drive Shaft with a 2 door and with the Automatic the issue is the rubber boot will rub against the Auto tranny skid plate.
Old Jun 30, 2010 | 01:36 PM
redx08's Avatar
You will be fine running the TF leveling kit, no driveshaft needed. I am not running it, but have several friends running 2 inch bb without drivshaft issue.
Old Jun 30, 2010 | 07:18 PM
Do your friends have the auto transmission? I've heard from others that the boot will rub and tear. What's your friends experience?
Nathan
Old Jun 30, 2010 | 09:31 PM
redx08's Avatar
Nathan
Yes they have an auto. The boot tends to tear with 3 inch lift and longer shocks. If you run the TF leveling kit your driveshaft will not have a problem. Do it man you will be fine. Easy install maybe 2 hrs while bullshitting and drinking. I have 3 inch lift with 35's and a detroit locker in the rear that my wife drives more days of the week than me. If I thought it was unsafe it would not be on the road.
Old Jul 1, 2010 | 06:29 AM
Thanks for the guidance! One more question, does the TF kit look out of place with the stock size Rubicon tires? I can't afford to do the TF kit and the tires at the same time.
Old Jul 1, 2010 | 06:44 AM
Pluke the 2's Avatar
The Leveling kit and Budget Boost looks fine on Stock Rubicon tires.
With a leveling kit, you're going to find the most height in a new set of Bigger Tires
Browse the forum.
