Rusty's lifts ??
Old Feb 3, 2012 | 10:14 AM
  #61
Nkapalski's Avatar
Originally Posted by h20squirter
Anyone know of any issues with the Rustyz 3.25" basic kit and the 12's? I'm hopefully getting my '12 this weekend and really like Rustyz.
I run the Rustys advanced 3.25 lift on my '12 JKU rubi and have no clearance issues with the exhaust pipe. Guess it depends on your caster.
Old Feb 3, 2012 | 10:55 AM
  #62
RustysTech's Avatar
Sponsoring Manufacturer
Rusty's Off-Road
Originally Posted by Ryan0260
Shouldn't be a problem but you will need an exhaust spacer. I run this lift on my 07 and am happy with it
We have done a lot of 12's and so far so good, there is clearance, we would still suggest checking it or maybe upgrading that front driveshaft, just in case.
Old Feb 3, 2012 | 11:39 AM
  #63
Blade's Avatar
If you look on my profile I have an album that proves the clearance of the exhaust to be a myth. You are good up to a little over 4" of lift with no rubbing. However, the driveshaft is over extentended at the CV joint and causes a pinch at the seal on the bottom. You will want to budget for a coast driveshaft in the not too distant future as you will need it. Best of luck, install is easy, and you will love the ride.
Old Feb 3, 2012 | 12:13 PM
  #64
GreenJK07's Avatar
Would I need to replace my drive shafts front and rear in my 2 door with the basic kit? I wheel hard and can't afford to do both right now. If I would need to do so, I would rather wait and do it all at one time.
Old Feb 3, 2012 | 12:32 PM
  #65
Blade's Avatar
The front would have to be eventually but the rear seems to be fine. The front you could get away with for a while, maybe a year or more.
Old Feb 4, 2012 | 08:19 AM
  #66
GreenJK07's Avatar
Thanks. I'm running a 2 1/2" rubicon express right now with stock shafts and I'm going to Jump to this kit and 37's. I will have all 8 arms and new shafts before I do that, but it's going to be piece by piece.
Old Feb 4, 2012 | 07:10 PM
  #67
Jkmedic231's Avatar
So if I were to get the 2" basic, what else would I need to do? Cuz a lot of lifts come with way more parts compared to rusty's. Just thinking what all would entail of extra cost, maybe easier to just go with a TF 2.5" ::
Old Feb 4, 2012 | 08:09 PM
  #68
armycop's Avatar
If you want to do the Rusty's 2", you should probably get longer swaybar links, and if you plan on running a tire larger than 33" you may need longer bumpstop extensions. I ran this lift on my 2007 with 35's. I bought the Full Traction bumpstop extensions and the TF brakeline drop brackets.
Old Feb 4, 2012 | 09:52 PM
  #69
ninjajmoney's Avatar
So i was looking at these coils but wanted to know if the people who are saying the ride is rough are using the rusty shocks?
Old Feb 5, 2012 | 05:17 AM
  #70
jeep2007's Avatar
Yes. Rusty's shocks are firm on highway, but IMO perform well off road.
