Rythmatic Vibrations on a 2DR!
Old Jun 8, 2010 | 02:22 PM
jason0341's Avatar
Exclamation Rythmatic Vibrations on a 2DR!
Let me start of by giving some specs.
TF 2.5 Coil Lift w/ shocks,
JKS Front Adj. Trackbar
Woods SS Relocation Bracket
TF HD SS
33" Km2's, 17x8 Black Rocks
I installed the lift 2 weeks ago and have had no issues at all.
Yesterday I installed my JKS Frnt. Adj and the Woods SS Relocation Bracket.
On the way home I noticed that starting around 55MPH and Up I feel a Rythmatic Vibration going on. Almost as if something is pulsating.
Today after work I removed the JKS and put my OEM back in place took a spin and it is still there. Just trying to see if the new installed parts might be causing something. I am getting ready to remove the SS and see if that helps (which i am sure it won't). Looking for any help or suggestions. I was really not budgeting in the price of New Driveshafts and figured I could get away with the OEM for a while
Also no torn boot, dents, or grease anywhere
Old Jun 8, 2010 | 03:28 PM
jason0341's Avatar
Anyone? Moderators, sponsors,members with thousands of posts?? I know plenty people running this setup. Any help would be awesome.
Old Jun 8, 2010 | 04:41 PM
Ryanc's Avatar
Your tires are most likely imbalanced.
Old Jun 8, 2010 | 06:20 PM
jason0341's Avatar
I was wondering that? Maybe I threw a weight somewhere over the past two weeks I am going to try and get them balanced tomorrow along with an alignment.
Since I don't have Adj. LCA's will the alignment really do me all that good?
Old Jun 8, 2010 | 06:43 PM
mkjeep's Avatar
Well,they can center your front axle, center your steering wheel and adjust toe. Or you can do that yourself. You probably have a tire bal prob, if not your driveshaft may have thrown a weight.If I were you, I'd just get the tires balanced, then look at your DS.
Old Jun 8, 2010 | 06:47 PM
lbwhotrod's Avatar
Agreed. check the less costly stuff first
Full-Traction Suspension's Avatar
Former Member
Have you checked your driveshafts? is the rear spitting grease?
Old Jun 8, 2010 | 07:05 PM
runit3's Avatar
x3 on the driveshafts and tires.
I noticed my driveshaft vibes from directly beneath the arm rest/console between the front seats. I've also had tire vibes and those usually feel directional for whichever tire(s) are off i.e.- front left, rear right, etc. and a lot less severe than DS vibes.
Old Jun 9, 2010 | 12:24 AM
sam08's Avatar
Default Installed the same lift and get vibes btwn 50-55 mph
TF HD SS
I installed the same lift and get vibes when driving steady abetween 50 and 55 mph
Old Jun 9, 2010 | 04:48 AM
Ryanc's Avatar
Originally Posted by racer83l
do you feel it in the steering wheel at all?????
That deffintely will help differentiate, good call.
