Scraped front diff and banged rear diff on rock
Old Feb 17, 2013 | 03:07 PM
JK BRO's Avatar
Was out a couple weekends back and ended up catching my front differential on a rock. Sheared the cover and housing on the bottom of it and as a result broke the seal and I'm leaking oil. See pics.
ID:	423459 Click image for larger version
Also managed to bang and scrape my rear differential housing and cover. The housing has a dent in it and it seems to have caused a structural crack (to the right of dent) on the surface of the rear diff housing (see surface rust areas in pic, one is the dent and to the right of it is the crack). Also leaking oil from diff cover in the rear as the scrape/impact jarred the seal.
Hoping this isn't a bigger problem then just the RTV sealant needing replacement. Thoughts?
Hit the rear diff pretty hard...
Old Feb 17, 2013 | 03:11 PM
swaite3's Avatar
Front is not an issue that a new cover and rtv can't solve but the rear is def an issue. Never seen a dented cracked center section before but I would say start looking for a new 44 rear as I don't that ones long for this world
Old Feb 17, 2013 | 03:12 PM
Maertz's Avatar
Attachment 423459 Attachment 423460
Also managed to bang and scrape my rear differential housing and cover. The housing has a dent in it and it seems to have caused a structural crack (to the right of dent) on the surface of the rear diff housing (see surface that areas in pic, one is the dent and to the right of it is the crack). Also leaking oil from diff cover in the rear as the scrap/impact jarred the seal.
Attachment 423461
Attachment 423462
Attachment 423463
id personally get new dif covers to be safe, but new rtv may do the trick. If it doesnt your out the oil and rtv costs....
Old Feb 17, 2013 | 03:55 PM
JK BRO's Avatar
Yeah I'm worried the structural damage on the rear is going to be a bigger problem then just the seal. Anyone else have any input or experience
Old Feb 17, 2013 | 04:05 PM
BrowniesJK's Avatar
You must have hit that rear pretty hard. I'd get some new covers and RTV. Keep an eye on the crack. If it starts looking wet, you have a problem. I'm sure you could get a welder to patch that up. If you can shave a 14 bolt you can patch a 44 :-)
Old Feb 17, 2013 | 04:06 PM
familytime's Avatar
JK Forum Regional Rep
Take it to a welding shop to see if it's repairable
Old Feb 17, 2013 | 07:10 PM
JK BRO's Avatar
Yeah thanks for the input guys
Old Feb 17, 2013 | 07:19 PM
ToolManTimTaylor's Avatar
Where in CT are ya again ? I have a set of OEM D44 covers if ya need 'em. I don't need the X-Member but if ya need the covers ....
Old Feb 17, 2013 | 07:23 PM
BTW A buddy of mine is up your way~ish? Hawker Metalworks. He can come to YOU and patch that diff with his rig if you need.
Old Feb 17, 2013 | 07:53 PM
JK BRO's Avatar
Hey Toolman I appreciate the offer big time. Northwest portion of the state. I might just take ya up on either of those offers but ill let ya know within a week or so. Thanks again man.
