Securing sway Bar when disconnecting PICS....
Old Apr 17, 2017 | 08:42 PM
rsmwrangler's Avatar
I have the TF quick disco's, and i was rubbing the links badly with the TF bracket and KO2's in 315/70/17, it would happen with the wheels at full lock and shocks fully compressed.
So i fabricated a different solution with a couple of L brackets from Lowes, zero rubbing now
20170331_144051 by Wrangler RSM, on Flickr
20170331_144113 by Wrangler RSM, on Flickr
20170331_142733 by Wrangler RSM, on Flickr
20170331_142746 by Wrangler RSM, on Flickr
Wheel at full lock and compressed to the top
20170408_142440 by Wrangler RSM, on Flickr
Old Apr 18, 2017 | 07:11 AM
Mike H.'s Avatar
I have JKS quicker disco's, so they get removed by pulling pins and sliding them off the studs, and go in a plastic bag then into my recovery bag.
I have a short length of rope that goes through the hole in the frame, and then I tie the sway bar in place at frame height.
Old Apr 18, 2017 | 07:31 PM
jtphoto JK's Avatar
Originally Posted by rsmwrangler
I have the TF quick disco's, and i was rubbing the links badly with the TF bracket and KO2's in 315/70/17, it would happen with the wheels at full lock and shocks fully compressed. So i fabricated a different solution with a couple of L brackets from Lowes, zero rubbing now 20170331_144051 by Wrangler RSM, on Flickr 20170331_144113 by Wrangler RSM, on Flickr 20170331_142733 by Wrangler RSM, on Flickr 20170331_142746 by Wrangler RSM, on Flickr Wheel at full lock and compressed to the top 20170408_142440 by Wrangler RSM, on Flickr
Interesting. Is your axle pushed forward ? My 37s don't rub ...
Old Apr 18, 2017 | 10:46 PM
GTJeeper's Avatar
I have the TF quick disconnects also. I think it depends on lift and tires, when I was at stock height my tires would run the top studs at full flex and turning, now with about a 3" lift no more rubbing, now I don't have to fix the rubbing issue 👍
Old Apr 19, 2017 | 04:59 AM
tarpon4me's Avatar
JK-Forum Ambassador
My way is super easy and cheap. Once disconnected, I rotate the link and set it on top of the sway bar, then Velcro it in place around the frame. Been using the same strip of Velcro for 3 years. Just leave the Velcro wrapped around the frame when not holding the link so I never have to worry about forgetting it. I have teraflex discos, but the bracket rubbed. This was my solution.
Old Apr 19, 2017 | 10:51 PM
I think is more the lift height ? i have adjustable front lcas, little longer than stock to accomodate the 2 1/4" lift, 5* caster
This is with a 2" bumpstop, look how the tire is rubbing the edge of my flares, i had to trim those with a grinder and hammer down a bit of the tube to avoid rubbing my tires
20170408_142021 by Wrangler RSM, on Flickr
20170409_123446 by Wrangler RSM, on Flickr
Zooming in
20170408_142328 by Wrangler RSM, on Flickr
20170408_142352 by Wrangler RSM, on Flickr
after massaging the flares
20170409_121122 by Wrangler RSM, on Flickr
No more rubbing
20170409_123503 by Wrangler RSM, on Flickr
And the tires finally won't rub the links in the new spot
20170409_123540 by Wrangler RSM, on Flickr
Old Apr 20, 2017 | 04:58 AM
sea bass's Avatar
I think it also depends on up travel. Only running 2" bump stops, or the guy who rubbed when stock will got more up travel than the typical guy running 37's. the axle will pivot more and lean the tire in.
Offset and tire size matter too.
Just a thought
