Shafted !!!
Old Jan 1, 2018 | 07:33 AM
lowjack989's Avatar
Question Shafted !!!
Need a front drive shaft...Looking at these two:
https://www.northridge4x4.com/fits/2...lts-and-flange
https://www.northridge4x4.com/part/f...-line-front-at
Anybody use either one of these?
Old Jan 1, 2018 | 08:51 AM
Ryan0260's Avatar
I am running Adams shafts, and they are top notch. Highly recommended. I would also get the sealed joints.
Old Jan 1, 2018 | 09:58 AM
Runewolf1973's Avatar
I was told by a mechanic that non-greasable joints are the best because grease ports can pose an avenue for dirt and grime to get in. I ended up getting the Coast 1310 drive shaft and I am very happy with it.
Old Jan 1, 2018 | 10:22 AM
Billbikes's Avatar
I have Adams shafts. I would get the solid front joint a bit stronger although you still need to grease the double cardan ball.
Try calling Adams they may be able to do a slightly better price, and you'll get a T-shirt. 😁
Old Jan 1, 2018 | 12:51 PM
nthinuf's Avatar
This might be worth repeating. Regardless of what type of ujoints you choose, you'll need to pull the shaft off to get to that one. At least I have never been able to get to it while installed.
Or maybe there is a sealed ball available now?
Old Jan 1, 2018 | 01:48 PM
Billbikes's Avatar
As far as I know there's not a sealed ball and it is a whole lot easier to grease removed, although I have done it without. I have one of those pointed extensions that I bent a little bit.
Old Jan 1, 2018 | 02:49 PM
nthinuf's Avatar
Nice, just might have to try that. I'm getting too old and lazy to want to pull that thing just to grease a single joint.
