shifter shaking
i have not had the normal rattle like others have posted here i am noticing after i swaped drive shafts from the stock to a rubicon express shaft it shakes at starts when i hit the right rpm about 1500rpm and then ir smooths out not once did i notice it shake with the stock shaft could it be caused by an unbaleneced drive shaft or the fact that the pinion angle is adjusted to compensate for the lift
