Shock boots
Old Sep 21, 2009 | 11:46 AM
gakpad's Avatar
Default Shock boots
I have noticed several jeeps without shock boots.
Is it ok to run without the shock boots?
I have a set of rancho 5000s and would like to remove the boot if it does not damage the shock.
Thanks
Old Sep 21, 2009 | 11:52 AM
mkjeep's Avatar
It won't damage them to run without boots. They tend to keep more in than they keep out.
Old Sep 21, 2009 | 12:04 PM
i though the boot was to keep the seal clean. if installed properly nothing should get in i'm not saying they are very important as some really good shocks don't even have any
Old Sep 21, 2009 | 12:34 PM
wayoflife's Avatar
JK-Forum Founder
just say NO to shock boots. from experience, i can tell you that they do nothing more than serve as a trap for water, mud, dirt, debris and salt. over time, they will rust out your shock shafts and that will damage your seals. even when install properly, there are still holes on the shock ends and in the boot itself to help it breath as they extend and collapse. this is where your gunk gets in and why it stays in.
Old Sep 21, 2009 | 01:38 PM
txjeeplover's Avatar
Agreed! I had a set of Rancho 9000s on my old ZJ and I made the mistake of using the boots. The boots retained water and debris around the top of the shock that would have ran off without it. That caused my seals to wear prematurely, the shafts to develop rust, and the body of the shocks to rust where the boot was attached. Haven't used them since and never will again.
Old Sep 21, 2009 | 01:41 PM
no boots it is
Old Sep 21, 2009 | 01:43 PM
whpony96's Avatar
Just say NO bud.... Shock boots do more harm than good.
