Shock install
Old Oct 14, 2011 | 07:00 AM
Greenmachine's Avatar
Default Shock install
Are aftermarket shocks in the rear supposed to be mounted shaft up or down? Are they labeled for orientation? I see some both ways. I know this such a noob question but just curious.
Old Oct 14, 2011 | 07:17 AM
RedOffRoad's Avatar
some go up, some go down. you will be able to tell when you are doing the install. they will have side mount holes for bolts for the bottoms and the fronts will have threaded studs on the top, the rears will have two wings coming off the sides that bolts use as "catchers" to hold it in place for the top part.
Old Oct 14, 2011 | 08:12 AM
Well I got the front. The rear came with the bar pins not installed. I guess the shock should be marked
Old Oct 14, 2011 | 08:43 AM
blue project's Avatar
My Bilsteins came shafts up in the front and down in the rear.
Old Oct 14, 2011 | 10:11 AM
sa29560's Avatar
Just got some new es9000s and the rear shocks were designated.
The fronts of course only mount one way. Bar pins were not installed, so if they were not labeled i would have asked the same question.
Old Oct 15, 2011 | 05:47 PM
Thanks. They are labeled
