Which shocks=most articulation
Old Nov 5, 2011 | 06:27 PM
PAGary's Avatar
Default Which shocks=most articulation
I have 3" of lift and 35"s. I'm looking for a shock with the most travel... putting on flat flairs so I will have a lot of room for up travel also.????
Old Nov 5, 2011 | 07:04 PM
RanchoRubi's Avatar
Have exact same setup. currently running Bilstein 5100s that originally came with 2" lift. Just as interested in hearing experiences.
Old Nov 5, 2011 | 07:25 PM
Loadbreak's Avatar
Make sure your brake lines are long enough for the extra flex though.
Old Nov 6, 2011 | 12:43 AM
bigljking's Avatar
Check with Dave at Northridge 4x4. They carry Old man emu long travel shocks. I think these would be just what you are looking for. If you do a search you can find a lot of info on here about them.
Old Nov 6, 2011 | 03:42 AM
PAGary's Avatar
Good ideas, I'll give dave a try and see what he suggests...
Old Nov 6, 2011 | 03:52 AM
renpia's Avatar
Your shock at full extension should match your coil at full extension. Otherwise the coil will drop out if your shock is too long. You would need a limiting strap or coil spring retainers to hold them in.
Old Nov 6, 2011 | 04:27 AM
orfanidisnikolaos's Avatar
OME long travel will do the job. Very nice shocks.
