Shortend Antenna? Anybody?
Old May 18, 2009 | 10:51 AM
Comicnut25's Avatar
Default Shortend Antenna? Anybody?
I've seen it before but never heard anything about people shortening there antenna? Wouldnt this make the radio signal a little more difficult ? Or is it still strong enough? Also does this affect surious sat radio?
Thanks!!
Old May 18, 2009 | 11:11 AM
ITSHERJEEP's Avatar
Cool
It does not affect the sat radio at all, but we installed an antenna from stubbyantenna.com and the radio signal is A LOT weaker than the stock antenna. We loose local staions very easy around town
Old May 18, 2009 | 11:16 AM
Comicnut25's Avatar
Good to know! Thanks for the quick response you guys are always on top of it around here!
Name:	Ocean Shores 09! 021.jpg
Old May 18, 2009 | 11:22 AM
scotlandjk's Avatar
i took mine off and covered it with a trail rated badge. works 10 times better than stock.
Old May 18, 2009 | 12:38 PM
greenamphibious's Avatar
hey I like that. I hate the oem one cause it always smack my windshield frame when I drive under trees and parking garages I like the trail rated cover up and winshield mount antenna Plus it is one less thing for da brus to be stealin from me
Old May 18, 2009 | 10:22 PM
bryz_rubi's Avatar
I installed a short rubber "Euro" style antenna from a seller on Ebay. (antenna_x)
$9.99. I'll post some pics to get a better idea what it looks like. No problems with radio station reception.
Also the SAT antenna is a separate antenna (little black box) underneath the center console top cover. I had to relocate it when I put the Tuffy Flip n' Lock cover in.
The stubby/rubber antenna doesn't bang into the garage door header and it won't get stuck on any tree branches. One thing I noticed in a snowstorm the stock antenna had a bunch of snow collecting on it and it started swaying back and forth. Thought it was going to break off.
As far as radio reception I guess it really depends on where you live?
Old May 19, 2009 | 02:26 AM
pearl-drum-man's Avatar
Originally Posted by toad
Why do you want to shorten your antenna?
I did a tight trail in AZ a few years back with my TJ. Thanks to some brush, my antenna ended up getting pushed back into and poked right through the soft top over the door sill. I keep meaning to do something about the JK antenna, everytime I pull into my garage it hits the entryway and whips around.
