In this situation, do i need a new Driveshaft?
My buddy is selling me axles with 5.13 gears and ARB Lockers.
I have a D30 (infront) & D44 (rear)
*Do I in this situation need to get a new driveshaft with this set up or is stock ok to use.
If I do need a new one, why is that the case?
Originally Posted by Youri
The stock driveshafts will be fine. New axle doesn't require new driveshafts, it's when you lift a jeep that you worry about driveshafts.
You will need new driveshafts because of the lift height, shock length, model, transmission type, axle centering, type of use, etc. Not because of your choice of gears/lockers.
Higher (numerically) gears will have your driveshafts spinning faster, though, so it may be more noticeable if you have balance issues with your current shafts.
you should look into replacing the driveshafts at some point anyway, the stock one's are pretty weak. Also make sure you notch the skid underneath the front one with that lift, it's usually the one that takes a knock at full flex. it's a small cut that gives it about an extra inch or so of clearance and peace of mind. I didn't do this....which lead to new shafts.
But no, other than speeding up the driveshaft rotation, the new gears should not affect the need to replace shafts.
