View Poll Results: RockHard4x4 OR Treks, which do you like the look of more?
RockHard4x4
26
60.47%
Treks
17
39.53%
Voters: 43. You may not vote on this poll
Skidplates
Also, the transition right under the oilpan seems smoother and more gradual on the RH set.
How well do those washers seem to be holding up? As there are more of them exposed with washers on the RH than the rounded head (seem somewhat countersunk?) on the Treks. Do the washers come right up or past the edge of the bolt heads?
Also, the transition right under the oil pan seems smoother and more gradual on the RH set.
Sliders:
So far from what people have posted here and on other threads the RH stuff seems to be mostly well built. I don't care for the fitment of the Sliders after PM'ing several users and seeing higher-res photos. Anything that mounts to a body panel should be tight and sealed OR not mounted, and then spaced away decently to let water/gunk away from the panel. So for sliders I'm still thinking the Treks, or ShrockWorks. I think I'll stay away from body-panel mounting sliders altogether.
Skids:
I'm going to PM RockYacht from Treks and ask some questions. Baring anything more negative than what I see with other products I'm looking at them for skids. And most likely for sliders. The short g/f won't like it, but it's not her ride.
Skids:
